What did you do to your Escape today?
Talk about anything related to your Escape, Mariner, Tribute, Maverick!
Re: What did you do to your Escape today?
Postby thesavo - October 6th, 2019, 5:11 pm
The rain came earlier than expected. I only got the ptu/transfer case fluid changed. The rear Differential will have to wait for another day.
I should take care of some of the rust. But that is a story for another day. At 188,870 miles, the transmission got 3 1/2 Quarts, the Ptu got 12 ish ounces, and the tires got rotated. Though, I probably need new front snow tires. The grease boots on the tie rod ends and stabilizer links seemed pretty packed from the spring.
Sent from my SM-N975U using Tapatalk
Postby Meatloafmountain - November 21st, 2019, 7:00 pm
Got new lights put in.
LEDs for the fogs.
Rigid lightbar.
HIDs for headlights.
Rear LED reverse lights. ImageImage
Sent from my SM-G892A using Tapatalk
* Blackhorse Grilleguard - Blackhorse Taillight Guards - Plasti-Dipped stock wheels - Plasti-Dipped grille - Spyder Headlights - Dawn Bodyside Molding - LED light bar - Ford Spoiler - Debadged - LED foglights - Tribute taillights - WeatherTech Lampguard Covers - Plasti-Dipped gas door - front air dam removed - TrailFX Rear Bumper Guard - No Boundaries Roof Rack
* WeatherTech Floor and Cargo mats - Saddleman Seat Covers - various Plasti-Dipped interior pieces - Greyman Tactical MOLLE boards
* Magnaflow exhaust - AEM Brute Force filter
* front strut tower bar - Moog Front Sway Bars - KYB Struts - H&R 1 inch Lift Springs, Front & Back - KONI Rear Shocks
* Optima Yellow Top battery
UpComing Mods / Repairs / Projects:
The Retrofit Source 2nd Gen Fog Light Thread | FTS 4X4 Adjustable Rear Lower Control Arm
Consolidated War Wagon Build Thread
Off Roading Thread
YouTube Offroading Channel
Meatloafmountain
My vehicle: 2012 Ford Escape XLT V6 AWD
My vehicle's name: War Wagon
Postby Skywoulf - May 17th, 2020, 1:58 pm
what did i do to my escape today..........
it is more like what did my escape do to me today.......
for the past 2 months i have been wrestling with the dreaded no crank, no start issue.
so i let the car rest for 2 days while i researched yet more possible scenarios for repair. i am beginning to suspect the PCM as it is the controlled ground signal from it that completes the circuit to energize the starter relay and engage the starter.
my issue in a nutshell is that the starter relay is not getting energized to switch the power from the battery to the starter.
for more information: https://www.escape-city.com/viewtopic.php?f=8&t=74226
Skywoulf
My nickname: Sky
My vehicle: 2006 escape xlt 4x4 v6 3.0
My vehicle's name: does it need one?
Postby thesavo - August 22nd, 2020, 2:15 pm
Oil change today. 196,573 miles on my 2008 mariner v6 base. Also changed my pcv valve.
I had bought one a few years ago to replace when I did spark plugs. After inhibitions, and misplacements, the moons aligned and was able to replace it without removing the upper intake.
Postby SNJEscape - September 11th, 2020, 8:33 pm
Had a noise in the r/s front which turned out to be a bad wheel bearing. I removed the knuckle & took it to a local machine shop to have the old one pressed out & a new one pressed in. I am going to re-install the knuckle tomorrow.
2000 Ranger XLT 4X4 Extd Cab 4.0L (My DD)Mods; bug shield, vent visors, bed rails, throttle cable, Mustang dome light, Expl OHC, Expl lighted visors, Expl radio trim panel, Ranger logo floor mats, 4.0 Emblems, 06 Mirrors, 01 F/E swap, lights behind the grille, step bars, color matched bumpers, Lund cab visor, tailgate light bar, yellow fog light bulbs, & powerdome hood.
2008 Escape XLT 4X4 2.3L Mods; Remote start, bug shield, vent visors, Explorer cargo area protector, Husky stickers, & yellow fog light bulbs.
1969 Mustang Coupe (Project & future toy)
2002 Honda shadow VT750 (Wifes toy)
1999 Explorer Sport 4X4, 4.0 SOHC, (Wife's DD) Vent visors, Bug Shield, & Grille Guard.
SNJEscape
My nickname: Mike
My vehicle: 2008 Escape 4X4 XLT
Postby SNJEscape - September 12th, 2020, 4:53 pm
Picked up the knuckle from the machine shop yesterday after work & installed it today.
SNJEscape
My nickname: Mike
Postby JohnThomasson - November 3rd, 2020, 3:21 pm
My Escape got hit while parked recently - hit and run. When they replaced the back glass they informed me that the hinges were bad. So, I replaced those. Replaced the driver side mirror that was smashed off as well, and did enough body work to the fender to pass inspection. The quarter panel was a total mess, and while I had never done body work before, I am satisfied with the results - even if its painfully obvious that an mature did the work ;-)
Also, I got new seat covers - Coverking Neosupreme. They were a little pricy but are awesome, and really improved the interior. Anyone else have problems with the seats in the 05 XLT? The fabric basically deteriorated and fell part.
I'd really love to upgrade the radio/head until next, but am concerned that I'd get it all part and have serious issues getting a screen installed.. So many question about shaving 1/16" off the dash, says modifications to the sub dash, and I can't be sure which head unit will pair well with an iPhone and provide Bluetooth capability to use the navigation from the phone and hands free calling. Plus the wiring harness looks like you still have to manually pair up and connect a ton of wires. You'd think they would make one that would plug into the OEM harness and then into the new head unit, like and adapter in between. Still too many questions to pull the trigger.
JohnThomasson
My vehicle: 2005 Escape XLT
Postby JohnThomasson - November 7th, 2020, 4:43 pm
JohnThomasson
Postby MTNEscaped - March 8th, 2021, 7:46 am
Castrol 5W-30W extended mileage synthetic oil change and filter, and replaced both stabilizer bar links (yesterday).
And...my inspection found my PS outer tie rod on it's way out that I'll replace in the coming days. :thumb:
2008 Ford Escape XLT 4WD
Plain Jane with K & N filter / Optima yellow top battery / Goodyear Gatorback serpentine belt / Sensen front struts
30+ years of ford parts that do me no good at all on MTNEscaped !
MTNEscaped
My nickname: Mtnman
My vehicle: 2008 XLT Escape 4WD
My vehicle's name: MTNEscaped
Postby MTNEscaped - March 20th, 2021, 6:07 am
Replaced the PS outer tie rod end, (have another one on the way even though the DS seems ok). Living on a dirt road the past 2.5 years is starting to take it's toll on MtnEscaped nowadays... :(
And at 87 degrees here most of last week, (yeah bragging rights that we Floridians pay for in August when it's a constant 99 degrees here LOL). :fan:
And I aired the tires up/added a pint of Dexcool coolant, (don't even want to know where that's going)...
MTNEscaped
My nickname: Mtnman
Return to Tailgate Chat
Users browsing this forum: No registered users and 56 guests
