Permanently disable auto stop/start?
Re: Permanently disable auto stop/start?
Postby Bilbo - October 10th, 2017, 6:18 am
I sometimes find the start/stop annoying but I try to view it as just different.
One of the annoying things is that the climate system does shut down but the car becomes very quiet if your tunes aren't playing.
Another is the power steering 'kicks' as it cycles when the wheel is slightly turned.
For me it rarely works as it should because it has to restart very soon after stopping.
Drive-through lines are a good example -.-.-.-.....
So, you can restart it easily enough by just lifting your foot from the brake pedal for an instant
Mrs B's:
2017 Silver SE 1.5 Eco boost. FWD
Retired.. :-( Redfire 08 XLS i4 4wd 71,771 miles RIP ESME
Bilbo:
2017 Magnetic SE 2.0 Eco Boost FWD.
Retired.. :-( Lil' "T" Black 10 XLT V6 Fwd 96,888 miles.
Retired.. :-( True Blue 2003 3.0L infidel fwd XLS
Bilbo
Postby Charles - August 6th, 2018, 9:51 pm
Found a YouTube tonight that might be what you are looking for. It involves the program Forscan (available at Forscan.org) and an OBDII Reader.
Link to OBD II Scanner used in the YouTube. OHP ELMconfig Elm327 OBD2 USB with HS-Can and MS-CAN Switch for all Windows Forscan compatible with Ford and Mazda
Do this at your own risk. You can SERIOUSLY mess up your ride if you are not careful. :yes:
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; K&W 500 Series Chest Toolbox
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row), Wireless Rear View Camera.
Postby 14theRoad - August 16th, 2018, 2:43 pm
I saw the age of the thread and almost didn't reply but yes, Auto Start/Stop features can usually be programmed in the vehicle's firmware. But, as Charles mentioned recently, you need a tool that can read/write Fords proprietary commands like Forscan.
VW/Audi have a similar requirement through VCSD, it was formerly called Vag-Com.... :D
Postby Jossef12 - February 12th, 2019, 9:34 pm
I believe someone will come up with a way to disable it. I have researched it and isn’t required by the government. There is a device that can be bought for the F-150 that permanently disables it. Much easier to get to switch on F-150 than the Escape. (You Tube video). The Escape S does not have Auto Start/Stop.
Jossef12
Postby Jossef12 - March 8th, 2020, 7:12 am
I have disabled the start/stop on my escape. It is a device that plugs into the OBD port. Just plug it in and that’s it. Takes less than a minute.
Jossef12
Postby hlh1 - May 5th, 2020, 8:23 am
Here ya go:
https://www.autostopeliminator.com/
I have one on my 19 Escape and it works great.
2019 Escape SEL 4WD 1.5 Ecoboost
hlh1
Postby bangster - May 5th, 2020, 5:01 pm
Not sure where they are putting $100 in gas in their tank, but that is a pretty steep price. There are a lot of those single purpose OBD port dongles and programmers, I am sure there is a little R&D to get money back for, but wow.
Postby Escapeism - June 14th, 2020, 6:55 pm
hlh1 wrote:Here ya go:
Have been using this for a couple months. Best purchase ever.
2017 Escape Titanium 2.0 4WD - Lightning Blue - Panoramic Roof - Tow Package - Sport Appearance Package
Escapeism
My vehicle: 2017 Escape Titanium 4WD
Postby thesavo - June 16th, 2020, 12:15 am
Forscan to the rescue. I haven't made this mod, but give it a try.
https://www.forscan.org/forum/viewtopic.php?t=3218
https://youtu.be/uAQ6kiHofG0
Sent from my SM-N975U using Tapatalk
