Hybrid acceleration issues
Finally, a forum for E/M/T Hybrid owners? What a concept!
Postby Aerostarnes97 - September 13th, 2020, 10:58 pm
Hi all,
I loved my 07 Hybrid until I started having issues with it. It started a year ago, happened once, then not again until 6 months later, when it became more frequent. The issue is that while accelerating, I lose rpms infrequently. The engine will accelerate fine until 4,000 rpms, and then it will feel like it’s stumbling and the rpms dip to 2,500 or so. I lose acceleration power, and the the rpms will climb back to 4,000 and all will be normal. The mechanic I took it to said it was something to do with the transmission/battery, but said it needed to go to the dealer. I ended up buy an ‘09 Escape, so I haven’t put time or money into it. It would be nice if I could figure what’s wrong to give a better idea to someone buying it from me, but I may or may not fix it depending on cost. Should I take it to the dealer? Or just sell it as is.... any ideas?
It has 135,000 miles, FYI.
Aerostarnes97
Re: Hybrid acceleration issues
Postby MAX_LT - October 3rd, 2020, 12:16 am
Is this right after startup, or randomly with a warm engine?
I have noticed with my '05 that it is always grumpy for a minute or so after a cold start. If I try to drive right away it doesn't respond well to the gas pedal. I've also noticed that charge/draw needle on the dash shows the electric motor drawing current for that first minute, presumably meaning the electric motor is assisting the gas motor to idle.
-Max.
MAX_LT
My vehicle: 2005 Escape Hybrid
My vehicle's name: Super Duty
Postby Aerostarnes97 - October 4th, 2020, 8:54 pm
It’s always with a warm engine.... this is not a response issue per say, it is well after the acceleration sequence is in play. Usually 5-10 seconds into acceleration up a hill
Aerostarnes97
Postby Tembrant - October 5th, 2020, 1:06 am
Does the assist needle do anything wacky while that happens?
Tembrant
My vehicle: 05 Hybrid AWD
My vehicle's name: Pruis's offroad brother
Postby Aerostarnes97 - October 8th, 2020, 1:35 am
you know, i haven’t watched it. It’s doesn’t happen enough times for me to know a pattern to predict it, and like i said in the post i don’t drive it any more...
Aerostarnes97
Postby barrythedude - October 14th, 2020, 6:12 pm
I would scan for codes before throwing parts at it. To me that sounds like a weak throttle body, but it could be anything from a coil breaking down to a bad spark plug, or cracked boots that sometimes arc. All things that are pretty easy to test tho.
barrythedude
Return to Hybrid Green Zone
