Hi,
I am the owner of a 2002 Mazda Tribute ES - V6 - 145K miles. Auto transmission. For the last several months, I have noticed a burning smell in the cabin. The smell was like burning rubber. It would come into the cabin when I would have my AC or vents on.
I had a leaking coolant tank that was dripping on the exhaust manifold. So that was replaced, but I still had the burning smell.
I went back to the mechanic and we found the power steering pump was leaking. So that was replaced. The burning smell went away and I thought we found the issue.
Last weekend I had a long trip where I was driving uphill and I smelled that burning smell. I looked under the hood and the smell was potent. I could not find where the leak was.
Currently, the problem only shows up when I have been driving uphill for at least several minutes. Reading through similar threads it could be a leak and airflow could be pushing fluid onto my hot engine or exhaust manifold.. I have checked my oil levels and my tank is full. I checked the transmission fluid and it is full too. I'm not sure if I have a leak with either system.
I'm reaching out to hear if anyone else has had a similar situation and could tell me what was your issue or any tips in trying to find out what is causing this? Because the problem only appears when I'm going uphill for a while, it has been hard to troubleshoot and the problem is somewhat livable but I'd like to get to the bottom of it if I could.
