Don't know if anyone has had this happen before but the other day en route back to school, I was going through a toll booth when my car jerked a bit then began losing speed. Instead of dying in the middle of I-95 I pulled along side the triangle after the tool booth where I noticed the engine was idling irratically and I had no accelerator whatsoever. The wrench (powertrain fault) light came on then I turned the car off. I started it back up but it took a while and then the rest of the way up to school felt like I had a loss of power and the engine barely went above 2 RPM if that. Did some research and found this:
http://usedcars.about.com/gi/o.htm?...42.ip_&tt=2&bt=0&bts=0&zu=http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
Have an appointment this friday so we will see what happens. Hopefully nothing too major. Something to do with the throttle control is what I found.
